Still leaking!
Old Apr 15, 2018 | 12:19 PM
SirNorman's Avatar
SirNorman is on a distinguished road
Default Still leaking!
I have a 1998 8S 10 blazer 4 x 4. We’ve had the fuel pump replaced twice and the gas lines checked and also the fuel fill spout. However when I fill it up with gas it still leaks. We have checked everything and I can’t find nothing else I am at a loss. Help
Old Apr 15, 2018 | 06:11 PM
newguy's Avatar
My 98 tank had rusted right through along the seam, couldnt see it without dropping the tank
Old Apr 19, 2018 | 06:45 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
Did you check the vent valve on the top front of the tank? It can leak around the o-ring or the nipple that connects to the vent hose can break off.
Old Apr 23, 2018 | 07:04 AM
LannyL81's Avatar
The fuel tank has a plastic vent at the front, very easy to get broken when dropping the tank. Might be able to view it using an inspection mirror, but there is very little space.
Old Apr 23, 2018 | 09:04 AM
ChuckNTruck's Avatar
If that plastic fitting the others have mentioned is not broken.
Have you checked to make sure the round rubber seal for the pump is sealing correctly?
I had a bad experience with a cheap aftermarket gasket.
On a 97 4 door that i used to own i changed the fuel pump and it leaked bad when full so i dropped the tank and pulled the pump back out twice before i finally put the seal that came with the pump next to a factory GM seal and the aftermarket one was a slightly different diameter. I then reinstalled the aftermarket fuel pump with a GM gasket and it never leaked again.
kuntryrebel88
Nov 3, 2015 10:46 PM
er0ck273
26
Jun 5, 2013 07:14 PM
davtak
Jun 28, 2011 08:47 PM
rmon
Feb 7, 2006 11:48 PM
vmx120
Sep 12, 2005 07:10 PM
