Stupid Smog Pump
Old Apr 3, 2009 | 08:29 PM
truesmack's Avatar
truesmack is an unknown quantity at this point
Angry Stupid Smog Pump
I have a 2001 4x4, lt, is there any way to take out the secondary air injection pump?? Its causing the dreaded damn check engine light from hell, I pulled the pump and managed to break off the pump part that connects the house, the plastic is brindle from the heat and hose was really on there, so now that I feel stupid I guess I have to make my way to the junk yard, Its more off any annoyance than anything, just wondering if anyone has an ideas, worst part of it is, I don't know if the motor is even bad, I got a replacement, but the one in there wasn't too bad, very little moisture in it, but it sum freely and whatnot, well anyways done for my night, maybe pick it up next week sometime, anyone have any ideas? thank you much.
Old Apr 4, 2009 | 03:46 PM
You have to get the PCM tuned to remove the AIR pump. It could impact your catalytic converter life.
Old Apr 6, 2009 | 09:36 AM
truesmack's Avatar
Yeah, I sorta was thinking that was the answer, not sure how could do that, guess I will have to find a replacement housing for the motor, any ideas?? I guess the bigger issue, not even sure that is whats is causing the damn service engine soon light, thanks.
Old Apr 6, 2009 | 10:00 AM
Well, if you want to find out what is causing the CEL, get the codes read.
Old Apr 6, 2009 | 10:01 AM
rriddle3's Avatar
AutoZone or Advance Auto will read the code for free. Let us know.
Old Apr 6, 2009 | 10:13 AM
truesmack's Avatar
Angry
Well I know its a code 0410, which is secondary air injection. First thought from what i read is the air pump, that is was going to replace the motor, but I broke the housing trying to pull the hose off is basically what happened, there wasn't much water in it thou, so im wondering if its the air check valve thing under the battery, I don't know, I'm not the most mechanical person, sorta learning as I go. thanks.
247monster
Jun 30, 2012 12:20 PM
99blazer4.3
Nov 15, 2008 07:34 PM
slk34
Jun 28, 2007 10:07 AM
jajfromga
Jun 17, 2007 05:15 PM
desrt_rat
Dec 22, 2006 04:10 AM
