Sudden electrical issues
Old Jan 18, 2012 | 09:16 AM
polartx's Avatar
polartx is on a distinguished road
Exclamation Sudden electrical issues
You guys have been super helpful in the past and hoping you can point me in the right direction.
No issues prior, one day I pull up to my house and open my door and notice the dome light isn't on. I put the key in the ignition and get nothing. Its almost as though the negative ground is disconnected because nothing has power.
I pop the good and look at the battery (terminals on the side, never worked with a battery like this before). Things seem to be connected but I move the cables around a bit and notice a subtle bzzz sound like current connecting. I check the car and I have battery power again.
Next day I start the car and its a very rough idle, if I give it gas it chokes and dies. Move the cables around a bit more, still terminals seem connected. Engine starts fine and have been able to drive for a couple of days like normal, except: When I turn off the headlights the radio turns off
Any ideas?
Old Jan 18, 2012 | 12:36 PM
First... What is it you're driving? There were several changes from 95 to the end of production when it comes to the radio & associated wiring. The year of your vehicle is the least of the information necessary to properly help you with your problem.
Second... Is it the stock or aftermarket radio? From the sounds of it, the illumination circuit is feeding into the switched 12V circuit for the radio.
The first thing I would do is disconnect your battery connections, cleaning them up really good, then reconnecting them, making sure to get them tight. There should be no movement with moderate force on the cables.
Old Jan 18, 2012 | 01:46 PM
polartx's Avatar
Sorry I forgot some info: Its a 95 S10 Blazer LS, It does have an aftermarket radio.
Great suggestions sqartlkk, I'll try that out!
Old Jan 18, 2012 | 03:04 PM
Definitely clean & tighten the battery connections first.
How long has the stereo been acting up?
jimi
Jul 24, 2012 01:48 PM
TheMoneyPit
Feb 18, 2011 08:31 AM
TDS-MN
Feb 7, 2011 09:05 PM
rooster
15
Dec 2, 2006 02:08 AM
BLAZINBlaZer98
Mar 1, 2005 10:53 PM
