Suggestions for getting CAT out???
Old May 11, 2007 | 07:19 PM
cmblackburn's Avatar
cmblackburn is an unknown quantity at this point
Default Suggestions for getting CAT out???
I have a 1998 blazer that I finally got loose(broke 5 bolts), which way do I need to try and get this Cat out? I would assume go toward the muffler, but do I need to remove the muffler to do so?
Also any suggestions on getting the old bolts out of the flange or is it pretty much time to get out the 3 pound hammer.
Thanks for any help.
Old May 11, 2007 | 08:01 PM
erauto's Avatar
erauto is an unknown quantity at this point
Default RE: Suggestions for getting CAT out???
just cut the flange, go to muffler shop, get a pipe and weld in
Old May 11, 2007 | 09:21 PM
I have already purchased a bolt on cat, I guess I could take it back but kinda wanted to keep the blazer in factory condition just in case I wanted to sell it.
Old May 12, 2007 | 11:09 AM
If you don't have air tools to get the old bolts out... It will probably be difficult. If you have a small propane torch (plumbers torch), then you can put a bit of heat into it and that may help to break things loose. You may have to cut the bolts off if nothing else works...
hillbillys10
Apr 14, 2013 01:04 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
