Sway bar link tightness?
Old Feb 27, 2013 | 01:23 AM
marklar's Avatar
marklar is an unknown quantity at this point
Default Sway bar link tightness?
So, there I was, replacing the sway bar link on my truck. I assembled the link, and went to torque the nut to 11 ft/lbs. It seemed like it would never torque- even had to get the deep socket for the nut. Once it torqued to 11, I was left with damaged (nearly split) bushings, and the end of the link bolt sticking out quite a ways.
My question is, do I really need to torque this down this tight (11 ft/lbs)? Or can I just have the nut on securely? It also seems like this is angled quite sharply... Is this a problem?
Attached Thumbnails Sway bar link tightness?-2013-02-25-11.49.19-copy.jpg   Sway bar link tightness?-2013-02-25-11.49.36-copy.jpg
Old Feb 27, 2013 | 02:29 AM
newguy's Avatar
Not needed just tighten it
Old Feb 27, 2013 | 08:05 AM
rexmburns's Avatar
Super Moderator
Yeah thats way to tight! You should replace the bad bushings and then retighten. I tightened mine just till the bushings were snug with a tiny buldge and they seem to work fine. I don't know if thats the correct way but it works great on my truck!
Old Feb 27, 2013 | 08:03 PM
ol' grouch's Avatar
ol' grouch is on a distinguished road
The end links are like shock absorbers when you tighten them down. Just snug it up until the rubber washers are just a tad past the edge of the metal cupped washer. Maybe an 1/8 inch past the metal all around.
NeMiZiS
Jun 7, 2013 12:47 PM
armstrong001
Mar 19, 2013 08:27 AM
porkfriedrice
Mar 30, 2012 01:41 PM
Yooper
Nov 6, 2009 07:26 PM
Bad Ramer Jamer
Sep 12, 2008 06:55 AM
