sWAY BAR END LINK RUBBING RIM ON FULL TURN?
Old Jun 3, 2013 | 10:56 AM
NeMiZiS's Avatar
NeMiZiS is on a distinguished road
Default sWAY BAR END LINK RUBBING RIM ON FULL TURN?
My blazer 1998 2 door s10 4x4 is rubbing the sway bar end link on the driver side wheel.
So far I have rebuilt most of the front end.
idler arm, pitman arm, wheel bearings, sway bar end links,upper and lower ball joints.Possibly more but that what I remember doing right now.
I have the front lowered via torsion bar bolt removal.
Any ideas as to why the sway bar end link rubs the driver side rim.
I'm pretty much at a loss, it was rubbing before the torsion bolt removal too.
I previously thought my cv axle was clacking because it only does it when I turn the wheel one way.
Thanks in advance for any help!
Old Jun 3, 2013 | 12:11 PM
liljoejoe54's Avatar
liljoejoe54 is on a distinguished road
My '88 used to do that and never figured out why either. If you figure it out, please post here, I think my '01 ZR2 might be doing the same thing (hear weird noises from front end when locked hard left).
Old Jun 3, 2013 | 12:14 PM
NeMiZiS's Avatar
I've been doing research all morning with little results.
I knew something was wrong when I was backing up and my front end spit out a piece of chrome off my wheel!
Old Jun 5, 2013 | 01:34 PM
NeMiZiS's Avatar
A little update.
I took the truck to the alignment shop, they said my drivers side wheel hub is bad.
Doesn't even have 5000 miles on it?
But I did buy a cheap one so maybe that is why it is bad already.
I'm thinking the bad wheel hub may be why it is rubbing the rim.
Old Jun 5, 2013 | 01:45 PM
newguy's Avatar
Because you change the suspension ride height changing your camber. Spacer will help
Old Jun 5, 2013 | 02:41 PM
NeMiZiS's Avatar
If that was the case wouldn't the sway bar end link rub on both wheels?
Not just the drivers side?
Old Jun 5, 2013 | 03:24 PM
newguy's Avatar
Not always, could be a tbar adjustment away
Old Jun 7, 2013 | 11:56 AM
NeMiZiS's Avatar
I just installed another new wheel hub and I still have the driver wheel hitting the sway bar end link.
I'm going to take your advice and put the t-baR bolt in on the passenger side to level it out some.
The passenger side sits a 1/2 inch lower than the drivers side.
Old Jun 7, 2013 | 12:47 PM
newguy's Avatar
I'm going to take your advice and put the t-bat bolt in on the passenger side to level it out some.
Hope it works!
WalkGood
Nov 19, 2015 09:21 PM
armstrong001
Mar 19, 2013 08:27 AM
porkfriedrice
Mar 30, 2012 01:41 PM
Yooper
Nov 6, 2009 07:26 PM
Bad Ramer Jamer
Sep 12, 2008 06:55 AM
