tach reads slow
Possibly the stepper motor that operates the tach needle is binding, or has a poor connection somewhere. The signal originates at the CPS, (Crankshaft Position Sensor) and is sent directly to the PCM. Serial data is sent to the BCM, and the BCM sends the data to the logic module in the instrument cluster. A bi-directional scan tool capable of accessing the BCM can force a needle sweep to see if the BCM can command the tach, and see if it responds correctly. Without the scan tool, diagnosis is difficult.
EDIT: correction
EDIT: correction
smoothedoggie
02-14-2009 04:38 PM
blazerguy22
12-12-2008 07:59 PM
