Tack bouncing at wot and power loss
Old Aug 25, 2019 | 02:25 AM
Corepbj's Avatar
Corepbj is on a distinguished road
Default Tack bouncing at wot and power loss
2000 blazer 4x4. Has a rough idle drives fine until trying to pass. The transmission kicks down and the tach bounces at redline (theres a clicking sound from the passenger side) and loses power check engine light comes on but goes away before I can check the code.
Old Aug 25, 2019 | 04:47 AM
Corepbj's Avatar
Was just looking around and discovered the maf was installed backwards so I turned it around rough idle is gone but still has the other issues. Also checked the trans fluid after test drive and its good.
Old Aug 26, 2019 | 07:18 PM
odat's Avatar
Why are you going to WOT to hit passing gear, do as you wish but can be hard on things.
Sounds like trans is slipping or down shifting too far when trying to pass and you are over revving the engine hitting the rev limiter and floating the valves.
Is the trans fluid pinkish or brownish / black?
How did you check the fluid level, on level ground, warm, running and park?
Old Aug 26, 2019 | 09:47 PM
Corepbj's Avatar
I went wot because of a short passing zone on a 2 lane highway. Yes I checked the trans fluid warm running and parked on level ground. The fluid is red and between the warm lines on the dip stick. I finally caught the code before it dissapeared it's P0335. So I need a crankshaft posititon sensor. Is there a way to do the relearn on that without going to a dealer? And is there a specific brand I should use?
spazblazer
Nov 27, 2014 02:58 PM
Naydog101
Apr 3, 2014 01:12 PM
sky_blazer
Jan 23, 2014 02:43 PM
crater
Nov 14, 2011 10:06 AM
Spartan66
Oct 17, 2009 09:20 AM
