trans slipping
Old Nov 26, 2014 | 03:10 PM
spazblazer's Avatar
spazblazer is on a distinguished road
Default trans slipping
I was on my way to work and was on the highway cruising and my blazer hesitated around 63 MPH then service engine soon came on and I stopped at a garage and had it diagnosed and it said trans slip and had the exact MPH. What's going on and how can I fix it cheaply. Father of 3 and an extremely tight budget.
Old Nov 26, 2014 | 07:18 PM
snuffy's Avatar
snuffy is on a distinguished road
What year, and how many miles?
You can try a fluid and filter change. You will need to drop the pan.
Old Nov 27, 2014 | 11:13 AM
Kev39kram's Avatar
Kev39kram is on a distinguished road
When i first got my blazer it had a slippy trans. Did a full flush and now its 2x better. But before you go about that the first thing to check is fluid level. Transmissions get very upset when they are low on fluid.
Old Nov 27, 2014 | 02:58 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Mine will do this every once in a great while. It was due to a bad radiator that had a leak at the cooler lines. I replaced the radiator and added a cooler. The thing is fine as long as I check the fluid level consistently. It may have a small leak else where but I havent found it but it is fine as long as the fluid is kept after. Im from an old school that says you should never change the fluid in an older trans because the high detergent will only disturb all the junk in the tranny and cause more problems. check the fluid level first with the car in park and the engine running and hot. It is easy to do
mnusn
Jan 8, 2012 08:15 PM
97jimmy4x4
Aug 22, 2010 02:48 PM
Spartan66
Oct 17, 2009 09:20 AM
oshkosh
Sep 4, 2009 10:27 AM
Brocktward
May 5, 2008 06:03 PM
