tailgate glass wont unlatch
Old Apr 15, 2021 | 02:26 PM
blackhawk61's Avatar
blackhawk61 is on a distinguished road
Default tailgate glass wont unlatch
2004 s-10 blazer......Electric latch quit working on tailgate glass with it closed. Makes a whiring sound when button is pushed and dont unlatch. HELP
Old Apr 15, 2021 | 09:28 PM
LannyL81's Avatar
There is a plastic piece between the solenoid and the latch that often breaks; sounds like this is what has happened in your case. There is a way to get the glass door open and the drop gate open, so all can be fixed.
Do a search here for "how to open a stuck rear window-tailgate"
Old Apr 15, 2021 | 11:55 PM
Rock18's Avatar
Rock18 is on a distinguished road
Regrettably common problem, they used a cheap part that's prone to failure. You need one of these: https://amzn.to/3mRcvOi
And replace it by doing something like this:
There are various other guides here if you do a search too.
Getting that tailgate panel off is a pain though, you essentially have to break a couple clips to do it. I would up using a hole saw to cut an access hole so I could actuate the lever manually, then covering it with a sticker. It's old truck anyway, don't care, and now my lift glass works again.
Old Apr 16, 2021 | 09:47 AM
LannyL81's Avatar
No need to do the above video to get the glass door open...follow the steps shown in the "How To Open A Stuck Rear Window". This gets the glass door open without breaking anything.
Now if the tail gate latch is broken...that is a different problem.
r_marczak_83
May 8, 2013 08:33 AM
cory30189
Jan 31, 2013 07:04 AM
wheeliemay
Sep 25, 2012 11:51 AM
truesmack
Jan 4, 2009 01:57 PM
MoneyPItJimmy
Feb 10, 2008 07:30 PM
