Taking right turn, brakes didn't work
Old May 29, 2009 | 10:51 PM
LindaChris's Avatar
LindaChris is on a distinguished road
Unhappy Taking right turn, brakes didn't work
Hi. I had an unusual incident happen to me earlier tonight. I was taking a right turn into the filling station, and when i applied the brakes to slow down, they made a strange noise.( that abs sound) I wasn't able to brake properly.....the truck kept going (slowly). It was as if I temporarily lost the brakes. I was trying to turn the wheel, but the truck seemed to continued moving straight. Good thing no one was turning to go out of the lot, I would have gone right into them. It happened several times tonight. Once I was away from other traffic, I turned off the truck. I then started it up again, and the ABS light remained on. The light is now off. I have a 96 Blazer. Would disconnecting the ABS fuse help? (I wouldn't mind regular brakes). Also, where is that fuse located? (Just curious). Thank you!
Old May 29, 2009 | 11:49 PM
mech cb's Avatar
mech cb is on a distinguished road
Have you looked at your brake-fluid? Make sure its not low or bubbly. If it is, you have a leak.
Old May 30, 2009 | 12:01 AM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
only thing worse than not being able to go fast is to no be able to stop!
Old May 30, 2009 | 02:37 PM
oisinirish's Avatar
Possible pinched wheel speed sensor wire?
Old Jun 1, 2009 | 07:29 AM
What is being worked on here?
It is possible that it is a pinched or broken WSS wire as mentioned above. It could also be a dirty WSS or one that needs to have the air gap closed up. Check out the Brakes - Low Speed (below 5 MPH) ABS Activation thread in the Tech Article (DIY) section.
MuddBunny84
Mar 24, 2011 06:10 PM
tnw912
Jan 5, 2010 05:27 PM
blazerJim1701
Dec 16, 2009 11:04 AM
ta3ff
Oct 14, 2009 05:07 PM
99 Blazer 4x4
Jan 17, 2009 12:47 PM
