Teflon for a check valve
Old May 4, 2015 | 11:35 AM
Robt77's Avatar
Robt77 is on a distinguished road
Default Teflon for a check valve
Is there a special teflon tape for high temp applications, or could I just put a little high temp silicone on it?
Old May 4, 2015 | 12:17 PM
What are you trying to do?
Old May 4, 2015 | 12:36 PM
LesMyer's Avatar
I know some people like to try to use it everywhere (like on flare fittings, etc), but PTFE tape is only good for threads that seal (pipe threads only)! I too am curious where you want to use it in a high temp application.
Old May 4, 2015 | 01:23 PM
Robt77's Avatar
Default smog pump check valves
I'm getting ready to replace the check valves for the smog pump. they are at the end of a piece of tubing about 6 inches from the exhaust manifold, so I'm guessing they are going to get hot. They are 3/4" pipe thread, so I imagine that they won't be air tight without some kind of sealer.
Old May 4, 2015 | 05:17 PM
Factory doesn't use or recommend using any type of thread sealer for the check valves. If I was going to use anything, it would be anti seize, so I can get it apart the next time it fails.
Old May 4, 2015 | 05:57 PM
Robt77's Avatar
Thank you, that's the way I'll do it.
marksoftball
Nov 29, 2014 09:27 PM
Chevy33
Mar 25, 2012 11:52 AM
89Recon
Oct 22, 2011 05:50 PM
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
bigdaddykane93
Dec 16, 2010 04:28 PM
