temp gauge drop off
Old Apr 30, 2009 | 08:41 AM
guywm25's Avatar
guywm25 is an unknown quantity at this point
Default temp gauge drop off
well I did replace my fuel pump this weekend and now while driving my temp gauge drops off and the car wants to stall or does stall. there is times that I can pedal through it but others not. why would my tmp gauge be droping out ? if it is air how could you bleed it out. I have tried driving around with rad cap loose.
Old Apr 30, 2009 | 11:01 AM
If it is not air in the cooling system, you may have a wire grounding out.
Have you recently serviced the cooling system?
Old Apr 30, 2009 | 07:05 PM
Check your fuel pressure and leakdown, sounds like a typical aftermarket fuel pump check valve problem, (VERY common).
Temp drop off might be faulty temp sender, low coolant level, (air pocket), or faulty thermostat.
zakm0n
Jan 9, 2011 07:31 PM
Malachai
Mar 27, 2010 10:00 PM
mboehler
Jan 16, 2009 07:16 AM
Mulisha
Mar 24, 2008 09:14 PM
naf821
Aug 8, 2007 07:19 AM
