Temp guage stopped working
Old Aug 20, 2010 | 05:03 PM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
Default Temp guage stopped working
So after I fussed with the 2-4wd vacuum control and hoses, now my temp guage indicates nothing. I assume I knocked off a connector or broke a wire.
Where is the sending unit and what did I most likely do.
I was under the battery support shelf, I was tugging the vacuum hose that runs from that actuator under the shelf and following it up across the engine to behind the distributor on the firewall.
Suggest a place to look for a loose wire I bumped in those areas.
Thanks.
Old Aug 20, 2010 | 10:07 PM
So I fussed with a couple connectors on some type of sensors in the area of where I was messing with the vacuum line and the gauge worked again for just a bit. So I know where I have to look more closely.
Schills
Sep 16, 2010 09:15 AM
bertrenolds
Dec 19, 2008 07:45 PM
myronhntr80
Mar 6, 2008 07:58 PM
mac6135
Dec 8, 2007 09:18 AM
