temperature
Typical for a bad ground. The sensor (whatever it is) is a variable resistor across the signal line to ground, when the ground opens, the sensor line has full voltage. Could be corrosion between the sensor body and whatever it screws into, or a bad sensor. If the ground from the engine to electrical systme was bad, that might harm the ignition, so that isnt my first guess.
