Temperature
Old Dec 28, 2005 | 07:40 PM
djestes's Avatar
djestes is an unknown quantity at this point
Default Temperature
Hello, In my 1995 4.3 blazer i'm having a problem with the air flow inside the car. Basically when I turn the pnuematic dial to say vent I get air flow out of the heater section. this happens on multiple settings. Reading some of the other posts I did replace all of the air lines under the hood but I still have the problem. I do hear a bit of hissing at the switch inside the car when i turn it to a setting but could this be it a new switch?
Thanks for all of your help.
Old Dec 30, 2005 | 11:33 AM
93LT's Avatar
93LT is an unknown quantity at this point
Default RE: Temperature
ORIGINAL: djestes
The only way to find out about the hissing sound is to take it apart and see if the vacuum line is bad or loose from the HVAC controls. If not, while the assembly is out, that would be the time to determine if the leak is within the unit.
RedBlazer 96
32
Jan 29, 2013 01:30 PM
Loofah
Apr 11, 2008 02:09 PM
redlineracerjpcb
Engine & Internal
Mar 16, 2008 12:35 PM
khalid_20879
May 12, 2006 03:57 PM
Ola Nordmann
Feb 1, 2006 06:56 PM
