ticking/clicking noise from under car
Old May 17, 2015 | 12:08 PM
zombieblazer96's Avatar
zombieblazer96 is on a distinguished road
Default ticking/clicking noise from under car
Replaced my rear axle assembly and ujoints on my 96 blazer, all was fine now I'm getting an intermittent clicking sound from under the car, only happens when accelerating and not when parked or shifted into neutral. Any ideas
Old May 17, 2015 | 01:51 PM
odat's Avatar
You can start with - check for wear in replacement diff, all shock mounts, loose u joint clips and u bands and brakes for wear and adjustment as a out of adjustment brake shoe or pad will vibrate and rattle
Old May 17, 2015 | 03:22 PM
It almost sounds like a metal hitting metal sound, it will do it at about 5-10 mph , i step on the gas and it does it, as soon as i let off, it'll stop, then step on gas and it's back. Can sometimes get it to stop by placing it in rev then drive.
Old May 17, 2015 | 04:07 PM
newguy's Avatar
check the dust shield
Old May 17, 2015 | 05:47 PM
odat's Avatar
also - check the heat shields over the cat ect. on the exhaust
supermario28
Mar 29, 2014 11:21 PM
crater
Nov 12, 2011 04:35 PM
Blazinflaboy
Jun 22, 2010 09:03 PM
willtoskie
Jan 10, 2010 04:56 PM
MM01Blazer
Apr 9, 2009 11:13 AM
