Tire carrier bolts on 05 2 door
Old Aug 15, 2019 | 06:47 PM
Dale Nichols's Avatar
Dale Nichols is on a distinguished road
Default Tire carrier bolts on 05 2 door
Nuts have broke loose and can't find a way to get to them
Old Aug 15, 2019 | 07:55 PM
Might have to drill them out and tap them... have you tried going from behind and using vise grips to pull them the rest of them way? Itll take a little long then drilling and taping, but more cost efficient...
Old Aug 15, 2019 | 08:52 PM
Blazin_Alexei's Avatar
Blazin_Alexei is on a distinguished road
I dont have a 2 door, But I put a tire carrier on my 4 door, it should be about the same. You can remove the plastic wall trim panel on the inside and fold the carpet back once removed. At that point i believe you can see all of the bolts(i can on mine) some of them go in to the side of the taillight area and you need to cut some of the metal out of the way to get a wrench on them. If you can get at them, definetlty use new bolts and nuts with Locktite. It's really pretty easy to take off the panel too, its all just clips, get a pry bar under them and they just pop off.
FUN-V
Feb 10, 2019 02:03 PM
username772
Nov 9, 2013 05:09 AM
JavierEscalonJr
Jun 26, 2013 12:45 PM
maddie's dad
Sep 2, 2011 07:22 PM
OILCOUNTRY
Mar 1, 2010 06:06 PM
