Tire still Rubbing and other problem....
Old Jun 9, 2009 | 12:05 AM
  #21
cr8390's Avatar
cr8390 is an unknown quantity at this point
bump also heres a new question along with my orginal one above thanks so much everyone
i just replaced the output shaft bearing and the axle seal on the passenger side cv its leaking cv green grease again and my tbars arent cranked that much only 1/2 inch to even out sagging. The drivers side (where the tire is rubbing) is not leaking at all. What does it leaking mean? does it mean it might need 2 be replaced soon?
Old Jun 12, 2009 | 03:32 PM
  #22
bandidolenny's Avatar
Not sure about the torsion bars... I know that there were several different part numbers with different levels of stiffness depending on the suspension package.
If the seal is already leaking then you either have a bad seal or maybe a bearing is beyond specs causing the shaft to move around and ruin the seal.
Old Jun 12, 2009 | 03:40 PM
  #23
cr8390's Avatar
alrightyyy thanks 4 responding ugh.... i just dont no wat to do about this stupid tireeee
Old Jun 12, 2009 | 04:06 PM
  #24
I may have been thinking of fullsizes... seems that the the S10 t-bars were all the same but the keys were different depending on the suspension package. Look at item number 18 on the attached link.
Back to your original tire rubbing problem... I think that maybe you have a weak torsion bar. Keep in mind that you should replace them in sets. They are not cheap but you could get a set of used ones from a salvage yard.
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=147
Old Jun 12, 2009 | 06:21 PM
  #25
cr8390's Avatar
i really appreciate it bandidolenny ill take a look at it idk if i wanna spend the money right now i just might look into a body lift eventually haha that would solve my problem the weird thing is this problem didnt start until i got the rock crawler rims, also are you sure its not a bad shock?
Old Jun 12, 2009 | 07:12 PM
  #26
okvortec's Avatar
This might be a pain, but put the stock rims back on and drive around for a few days. Post the results...
Old Jun 12, 2009 | 10:25 PM
  #27
cr8390's Avatar
thatd be a big pain and money i dont have 2 get the tires put back on the old rims i think the tire is hitting cause of the backspacing the rock crawlers have 4.5 where as the stocks and 6
Old Jun 13, 2009 | 01:38 AM
  #28
You could swap the LF and RF shocks and see what happens... Oh hell, just do the body lift. lol
Old Jun 13, 2009 | 10:43 AM
  #29
cr8390's Avatar
thats a good idea i may do that and yea im eventually going 2 do the body lift when i get moneyy
247monster
Jun 17, 2012 10:30 PM
davtak
Jun 28, 2011 08:47 PM
gstrat323
Tires and Wheels
Dec 12, 2008 11:09 AM
blazerboy30
May 27, 2008 10:22 PM
ryno
Apr 3, 2008 10:34 PM
