Top brake light, 97 Blazer
Old Oct 15, 2007 | 08:23 AM
joe's Avatar
joe
joe is an unknown quantity at this point
Default Top brake light, 97 Blazer
My top brake light is broken and I was wondering how to get to the connector that is underneath the roof. Looks like it's about a foot back and I can't pull it out far enough to get my fingers on the connector so I can unplug it. I've got the new light but just can't get to the connector on the old one. Does the ceiling have to come out from inside?
I also wanted to mention that I was posting here a while back about the brake lights and directionals on this vehicle (97). The car is in Puerto Rico, so I'm not able to just run out back and work on it. On my last trip there I brought along a new multifunction switch and installed it and now everything works. Thanks for all the help you guys provided.
Joe
Old Oct 15, 2007 | 08:26 AM
Default RE: Top brake light, 97 Blazer
You will have to drop the plastic panel at the back of the ceiling. This should give you access to the plug. I believe that the panel is held on with spring clips only, but look for any screws before pulling away at it.
Old Oct 16, 2007 | 05:35 AM
soundguy's Avatar
soundguy is an unknown quantity at this point
ORIGINAL: swartlkk
Yup, clips only (8), plug is behind wires for cargo lite. If you have 12v atthis plugwhen you press the brake, but no lite up - then... I scored one for $10 at a local pull your part, if you're not as lucky, they are avail on fleabay for ~$50 from a knockoff manufacturer, or dealership is $130. Good Luck! - Mike
jake kick
Apr 27, 2013 01:25 PM
JRock1944
Jan 31, 2012 08:46 PM
Firefighter502
16
Feb 14, 2008 01:51 PM
90blazinchevy
Oct 5, 2007 01:52 PM
bat119
Jun 26, 2006 09:04 PM
