Roof-top light grounding points?
Old Jan 29, 2012 | 09:45 PM
JRock1944's Avatar
JRock1944 is on a distinguished road
Default Roof-top light grounding points?
Alrighty, I bought some cheap "off-road" lights from Advance auto the other day, and I'm kind of stuck on where to ground them. I have the actual Switch grounded to my parking brake mount, but the lights themselves have grounds running out of the back of the casing. I've got some stereo wiring left over from my Z28 that I could attach/ run to a better grounding point. I'd just rather not do that, if possible.
The lights in question are "Blazer Baja off road lights" or some such. I bought them to experiment with roof lights, mounted onto the luggage rack. I've got the lights pulling power from the fuse box, if that's important in any way.
Old Jan 29, 2012 | 10:28 PM
warthogdriver's Avatar
I grounded mine to the bolt that holds the roof rack down..direct body contact...should work for ya
99bblazer99's Avatar
99bblazer99 is on a distinguished road
The screws holding down the luggage rack is where my friend grounded his old lights. just sand it down around the hole then you can wrap the wire around the screw or get a ring terminal for it and just screw you luggage rack back down.
Old Jan 31, 2012 | 08:46 PM
247monster's Avatar
i grounded mine on the inside where my jack goes...little more wire but you wont have to worry about it getting weathered ....just my sugestion lol
CPLSeraphim
May 20, 2014 05:48 PM
jake kick
Apr 27, 2013 01:25 PM
Blazer_LT
Jan 7, 2012 07:00 PM
Dano01
Dec 12, 2010 04:35 PM
90blazinchevy
Oct 5, 2007 01:52 PM
