torn rubber actuator?
Push in on the actuator, then put your finger over the nipple on the side (where the vacuum line connects) and let go of the cable. If you do not feel a suction of air when you pull your finger away, the actuator is faulty.
Rubber boot
I have 5 Jimmy's/ Blazers, each of them have 4 wheel drive, and if the boot is torn, cracked, or rotted away, there is not vacuum, which prevents the actuator from engaging.
But I have found a liquid (oily like) in the vacuum line going to the actuator, and this liquid breaks down the rubber, does anyone have an idea what this liquid could be I have replaced the actuator 2 times and not again till I find out where this is coming from
88 rusty but trusty
06-30-2010 05:40 PM
CheapBeer
05-26-2010 08:11 PM
