Tranny delays at shifting to reverse
Old Sep 8, 2013 | 07:31 PM
Bandit's Avatar
Bandit is an unknown quantity at this point
Default Tranny delays at shifting to reverse
Hi, guys!
I have 2000 LS Blazer 4*4 4.3L 4 doors 154k miles.
I noticing delay when shifting in to the reverse gear( any time, cold or hot).
It's like 2 sec.
Any suggestions?
Thank you.
P.S. Tranny has 50k after rebuild, the fluid changed 20k ago.
Old Sep 8, 2013 | 09:04 PM
Spree's Avatar
Spree is on a distinguished road
Fluid level still full?
Old Sep 11, 2013 | 05:08 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
im having the same problem but in drive too did you figure anything out?
Old Sep 11, 2013 | 05:20 PM
chris015's Avatar
i was reading around about this once and remember something about it being the reverse piston having a little bleed hole in it. over time your clutch pack wears and causes more volume to be filled thus taking a little long for it to shift. Nothing you can do but live with it. I dont think its a big problem,just another high miles thing you have to deal with.
edit,upon a lil more googling it could be a leaky accumulator seal. If i were you id try some lucas trans additive. its pretty good stuff.
Old Sep 13, 2013 | 04:05 PM
dman001948's Avatar
dman001948 is an unknown quantity at this point
Here is my 2 cents. Change the fluid and filter, that can do wonders for your tranny. I had my done at 50K and the filter was pretty dirty, fluid look kinda alright, but I went ahead and had it done anyhow. Going to do it again at 106K. Once them filters get all clog up its goodbye tranny....end of my 2 cents.
Old Sep 16, 2013 | 10:55 AM
Bandit's Avatar
Hi!
I just checked the tranny's fluid-looks little high. Do you think it may be a problem? How may I take it out?
thank you
P.S. transmission has been rebuilt at around 105K miles. Now I have 153K. Time to replace fluid?
Old Sep 16, 2013 | 11:27 AM
chris015's Avatar
when you checked it,was the car running,and hot? Cant check it cold sitting in the driveway with the engine off. take it for a 10 minute spin and check it in a level parking lot.
bwestbrook07
19
Aug 16, 2014 09:12 PM
TylerK10
Oct 8, 2011 11:55 PM
bryce
Mar 31, 2010 08:10 PM
Swblazer
Nov 14, 2007 07:43 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
