trans fluid out exhaust?
Old Aug 28, 2010 | 03:47 PM
BigWilly85's Avatar
BigWilly85 is on a distinguished road
Default trans fluid out exhaust?
I have a 1995 Blazer 4.3 vortek 4x4. I sent the truck to a shop to put a new distributer in it, while it was in the shop they told me it wasn't engaging into 4wd and said it was a vacuum issue. while they had it on the lift messing with the vacuum lines it started spewing smoke through the exhaust, they told me that it was oil and I needed a new motor. after closer inspection i found that it was trans fluid. any ideas?
Old Aug 28, 2010 | 03:52 PM
NVANZEE's Avatar
sounds like you need a new shop. You dont need a new motor just because there is oil being burned. It will probably need either new valve seals or piston rings. I dont think its even possible for trans fluid to get to the exhaust. How did you determine it was trans fluid
Old Aug 28, 2010 | 04:19 PM
BigWilly85's Avatar
the fluid that is leaking out of the exhaust is redish in color. I was told that if the vacuum lines are mised up it can back fluid up into the intake and out the exaust, but cant find where any lines are mixed up.
Old Aug 28, 2010 | 05:48 PM
NVANZEE's Avatar
was it fine before taking it to the shop? If so take it back and make them fix it since they messed with it
BrinkDiamond
Mar 2, 2014 03:50 PM
tim68
Oct 28, 2011 09:08 PM
DaleA
Jan 13, 2009 08:50 PM
luthers97blazer
Nov 10, 2008 01:27 PM
v8vairman
Apr 12, 2006 01:43 PM
