trans? Please help
Old May 6, 2011 | 09:02 PM
BresBlazy's Avatar
BresBlazy will become famous soon enough
Default trans? Please help
so im almost home and the blazer seems to get stuck in 1st or 2nd, i try to stop and it wants to keep going, i coast home and park and shut off, its smoking and leaking up front, also the trans pan seems to be leaking.....what now?
Old May 7, 2011 | 09:11 AM
ohsofly's Avatar
So what are we looking at? Leaking up front as in by the radiator? Or you mean by the front of the trans? Where is the smoke coming from a leak dripping on the exhaust? Or is the smoke blowing out the rear seal on the trans? If your fluid burned smelling? Is it overfull, underfull? I understand that when you stop, it is not free wheeling, it is still pushing forward and going against your brakes? It feels like you have your foot on the gas and brakes when stopped? Can the truck be put into neutral?
I have a feeling the tranny may be done if thats the case. What brought on the symptoms a hard shift and a bang?
At least you can cash and carry a trans for about 750 bucks from the rebuilder in your area. Im sure a hot woman may even be able to get one for less if the mechanic is impressed that she knows what shes talking about and is gonna change it herself.
Dont be scared, swapping the trans is not a crazt job, its just awkward as its under the truck and you may not have a garage. Im sure someone you know has a garage you could use.
Old May 7, 2011 | 05:44 PM
BresBlazy's Avatar
So, turns out it was the intake, had a big hole in a little elbow looking piece of hose, I found it by straying MAF cleaner around the intake area, in one spot the engine would rev real loud, so then I took a piece of hose and put one end to my ear listening for the spot where air was loudest.....found it, I took the elbow looking end off an old spark plug cable and put that in in its place....all fixed....for now.
thanks
Old May 8, 2011 | 03:48 PM
Frog's Avatar
Frog is on a distinguished road
Look at you go!!! Oh, Happy Mothers Day too!!!
Old May 9, 2011 | 10:16 AM
BresBlazy's Avatar
thank you!
ksunday1
Nov 5, 2013 02:22 AM
m.sterner
Nov 29, 2009 10:34 PM
rogggg1020
Nov 11, 2008 08:05 AM
luthers97blazer
Nov 10, 2008 01:27 PM
rob1621
Feb 29, 2008 08:15 PM
