Trans question
Old Aug 14, 2012 | 09:54 AM
Raybz's Avatar
Raybz is on a distinguished road
Default Trans question
Have a 97 Blazer with 4x4
Trans seems to be stuck in 2nd gear
It will cut power to itself at 2K RPMs
Threw a Solenoid B stuck code
I replaced A and B solenoids with no change
I did notice that when I popped the drivers side solenoid out that there was spring pressure on the valve but there was none on the passenger side one.
Is this normal or is it trouble in the valve body?
Old Aug 22, 2012 | 08:03 AM
Raybz's Avatar
Nothing?
No one?
Old Aug 26, 2012 | 12:05 PM
uncle_egg820's Avatar
uncle_egg820 is on a distinguished road
my 97 did the same thing. threw the same codes. rebuilt tranny with no improvement. after noticing several little "quirks" and after further aggravation and lots of research it ended up being the ignition switch. so if you have other little things going on it may be worth a look. this is a known problem for the 97's
Old Aug 26, 2012 | 12:31 PM
Rottidog's Avatar
If you changed the solenoid & still had the same issues & the same code, I'd check the wiring to it.
Old Aug 26, 2012 | 03:20 PM
step66's Avatar
Hmmm Valve Body!
Old Sep 28, 2012 | 02:21 PM
Raybz's Avatar
Ok...finally running again!
Took it to a guy that was suggested by someone I trust
Here's what was found/done
ALL solenoids and switches in trans were replaced. He said when we went to remove the accumulator switch it fell apart in his hand. Valve body was "rebuilt"
Turned out that the power issue was a clogged cat
So an Electronic rebuild on the trans, valve body gone thru and a new cat
$750 and it's cocked, locked and ready to rock!
Old Sep 28, 2012 | 02:49 PM
Raybz's Avatar
Running!
Took it to a guy that does trans work
He replaced all solenoids and switches and "went through" the valve body.
The power loss problem turned out to be a clogged cat
$750 and it runs like new!
Old Sep 28, 2012 | 04:22 PM
step66's Avatar
Wow! I cant believe it cost that much! But this just goes to show one can rule nothing out on these cars! And never take anything at original face value! I would have never guessed it was the clogged cat that made the trans issues more prevelent!
ksunday1
Nov 5, 2013 02:22 AM
m.sterner
Nov 29, 2009 10:34 PM
86blazeder
Feb 24, 2009 07:33 PM
luthers97blazer
Nov 10, 2008 01:27 PM
rob1621
Feb 29, 2008 08:15 PM
