Transfer Case harness / connector replacement
Old Feb 27, 2023 | 08:48 PM
Rathbone's Avatar
Rathbone is on a distinguished road
Default Transfer Case harness / connector replacement
I think I have a question that hasn't come up in the last 20 years on this forum. My 4WD stopped working on my 2001 Jimmy. I decided to look at the transfer case actuator connector to look for corrosion. The pins look good but I think the wires leading to the connector are corroded, thin, and 1 may have broken just ahead of the connector. How do I replace the connector? I can cut the wires and strip them again, but I need a connector to plug into the actuator.
Old Feb 28, 2023 | 06:54 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
If you are not able to find the specific connector, buy a full connector set and replace both ends.
Old Feb 28, 2023 | 07:06 AM
LannyL81's Avatar
The pins or terminals within the connector are removable, just takes care, patience, small screwdriver to do so. Then you can repair the wires, and if needed, replace the terminal(s), re-insert back into the connector body/shell.
Old Mar 1, 2023 | 06:09 PM
Rathbone's Avatar
It plugs directly into the switch on the transfer case, so I can't change both ends.
Old Mar 1, 2023 | 06:11 PM
Rathbone's Avatar
Have you ever done this? I can't re-use the terminals so where do you get such tiny terminals?
JasonGoneFishing
May 11, 2024 08:52 AM
jannes_z-28
18
Jun 19, 2022 02:13 PM
VANISH
Oct 1, 2012 11:59 PM
tsutton
Sep 13, 2011 03:43 PM
camino88
Jun 13, 2011 03:11 PM
