Transfer Case Input Seal Retainer Bolts
Old Oct 18, 2016 | 03:35 PM
a u d i o p h a s e's Avatar
a u d i o p h a s e is on a distinguished road
Default Transfer Case Input Seal Retainer Bolts
Hello,
So my grandfathers 95 blazer started puking tranny oil out of the vent pipe. Pulled the TC fill plug and drained damn near 2 qrts of extra oil. Ordered parts now I'm sitting here with the TC on the floor and... I CANT GET THESE DAMN BOLTS OUT!
Is removing the seal retainer a nesessity? I'm sure it is. These are on there friggin tight though. Not even my impact gun getting them loose.
Any ideas? help? or does anyone know where I could order a new set of bolts just in case we end up having to drill these out?
Attached Thumbnails Transfer Case Input Seal Retainer Bolts-img_20161018_132736259.jpg
Old Oct 18, 2016 | 07:02 PM
It is not necessary, nor advised to attempt to remove the input bearing retaining plate. Those bolts typically require heat to remove. The seal can be popped out and replaced without removing this plate.
Old Oct 18, 2016 | 07:31 PM
So it be. Thanks for the info. 2 guides I found floating around mentions removing it. and with no metal lip I was afraid of mucking up the rubber pounding it it. But we made it work without removing that plate.
Its weird because 2 of my jeepin buddies both looked at it and asked "why are there no bolt heads there". Maybe its a gm thing.
Thanks fot the help! I may return in the future is we run into more issues. My grandpas had this blazer since new and not sure if he'll ever get rid of it.
WBFAir
Sep 14, 2014 09:58 PM
Kocapuff
Oct 30, 2013 10:34 PM
wadespen
Sep 26, 2013 09:09 AM
Toby Hanson
26
Mar 14, 2013 12:30 PM
Eff10
Jul 12, 2010 02:32 AM
