Transfercase smell??
Old Oct 23, 2013 | 12:54 PM
Hank's Avatar
Hank is on a distinguished road
Default Transfercase smell??
Hi,
I did an oil change today, of the transfercase, oil smells burned!
Is that bad???
Old Oct 23, 2013 | 03:30 PM
chris015's Avatar
meh. hows the color looking?
Old Oct 23, 2013 | 04:26 PM
3 or 4 button switch on the dash? 3 button uses DexronVI ATF, red in color, there is a pump in the case, but no clutch pack. 4 button uses GM Auto-trak II fluid only, blue in color, there is a pump and a clutch pack in the case.
Old Oct 24, 2013 | 10:31 AM
Hank's Avatar
got 4 button, color is almost black.
Does it have an open or sealed viscous coupler?
Is there an exploded vieuw pdf available at the forum?
thx!
Old Oct 24, 2013 | 04:23 PM
Your transfer case is an NV236, (2 speed selectable / automatic). The exploded view is on pages 50 & 51 of this link: http://www.areds.com/wp-content/uplo...se-CD-Web1.pdf
The Transfer case requires this fluid:
Old Oct 24, 2013 | 04:33 PM
chris015's Avatar
captain,what would we do without you? I guess spent countless hours on google ha. you know the **** us regular blazer "pros" dont know LOL
Old Oct 24, 2013 | 04:44 PM
To be quite honest, I just found that pdf online I've got one for the NV233 in my 98 Blazer, but my 04 Blazer has the NV236. I much prefer the NV233 case. Much easier and cheaper to diagnose and repair and it gets better fuel mileage due to less drag in 2WD. I do like the electro vacuum switch on the NV236. No chance of fluid entering the HVAC system, like with the NV231 & NV233 mechanical vacuum switch.
Old Oct 27, 2013 | 08:37 AM
Hank's Avatar
Hi all,
Thanks for the info!
I've changed the oil by the Autotrack II oil, so thats finished!
Thanks for the pdf link, however, I still wonder if the clutchpack gets it lubrication from this oil,( ATII) or is it completely sealed with its own lifetime lubricant?
It's hard to see it's "open or closed".
I also did the Dexron III job!
Greetings, Hank.
Old Oct 27, 2013 | 02:33 PM
There's a pick-up tube with a filter on the end, you can see it in the exploded view. The pump circulates the fluid through the clutch pack to lubricate and cool it.
Old Oct 28, 2013 | 01:32 PM
Hank's Avatar
Thanks captain, now I see it!
chrisblaze
May 23, 2009 02:21 PM
blzR
Dec 19, 2007 05:44 AM
broken_blazer
Apr 15, 2007 02:09 AM
broken_blazer
Apr 13, 2007 01:25 AM
napalm dan
Jan 13, 2007 08:55 PM
