transmission slipping when cold
Old Nov 18, 2014 | 02:29 PM
3D_Illustrator's Avatar
3D_Illustrator is an unknown quantity at this point
Default transmission slipping when cold
My 2003 Blazer transmission has an intermittent slip in first gear when cold. I put two bottles of Lucas Transmission Fix in the transmission, and still have the problem. Some days it shifts perfectly, and other days not. I suspect the torque converter drains when rotated to certain positions when standing for lengths of time. It also makes more noise when it is slipping.
Is there anything else I can do?
Old Nov 18, 2014 | 03:45 PM
rexazz2's Avatar
have you changed the filter ?
Old Nov 22, 2014 | 06:06 PM
StarBlazing's Avatar
StarBlazing is on a distinguished road
Default Change the transmission filter
I second that... Change the transmission filter, filter seal, and fluid.
If the filter is partially clogged it is hard for the transmission fluid to flow properly. It gets worse if the outdoor temperature has dropped since the transmission fluid is thicker.
Old Nov 23, 2014 | 05:37 PM
04blaze43's Avatar
04blaze43 is on a distinguished road
I am having same thing in my 04 blazer it also helps to know what tranny u have if u have a deep or shallow pan if it is 3 inch it is deep if smaller you have shallow was just asked that at o'riley. Just so u are armed when u go.
bobby099
Dec 22, 2018 09:41 PM
kmclaugh84
Feb 11, 2014 07:42 AM
magtec
15
Nov 28, 2006 08:12 PM
timetoblaze
Nov 1, 2006 02:48 AM
MusicMaverick
Jan 26, 2006 03:27 PM
