Transmission trouble
Old Dec 18, 2012 | 03:26 PM
tjmaher4's Avatar
tjmaher4 is on a distinguished road
Exclamation Transmission trouble
Hey guys, i have a 2001 4x4 blazer and as of late ive been having some trouble. when i start it up theres no reverse at all, but if i hammer on the throttle it slams into gear after a few seconds, my neighbors are getting sick of hear it at 5am. also my 4x4 does not work itll only stay in 2 wheel drive. just wondering if i need a new transmission or what. Please help
Old Dec 18, 2012 | 05:38 PM
newguy's Avatar
If you keep treating it like that you`ll need a new tranny.
Old Dec 18, 2012 | 07:43 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Yea I would say new or rebuilt trans is in your near future , I'm rebuilding a turbo350 that has the same problem . If your mechanicly inclined there actully not that bad to rebuild yourelf . But once people know you can do it , its all you'll be doing .
Old Dec 19, 2012 | 07:57 AM
rexmburns's Avatar
Super Moderator
Here's a simple solution to keep from pissing off your neighbors back in at night!! Then you don't need to use reverse in the am
Old Dec 21, 2012 | 12:12 PM
Thogert's Avatar
^This.
Also, welcome from Utah.
Old Jan 4, 2013 | 12:16 AM
DKSDAD's Avatar
Welcome from New York.
Old Jan 4, 2013 | 08:36 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Welcome from Michigan
What is the trans doing in the forward gears?Is it going through them normaly or does it go into 1st hard also.Either the torque converter is shot or the trans is on its way.
Old Jan 4, 2013 | 06:00 PM
roypai's Avatar
roypai is on a distinguished road
had a car that would do this to me every so often except it'd be ANY gear and only when cold - once its going things are fine - never found the cause but to 'fix' it I'd slowly shift down through the gears manually to 1st, hover there for a moment and then select reverse or drive and it'd be fine for several weeks (or days - it was completely random)
Crawlerchris
Jan 4, 2010 06:37 PM
jman_08
Nov 12, 2008 08:47 PM
hoffy015
Nov 30, 2007 10:17 PM
pilgrim
Jan 21, 2007 07:23 PM
blazerrick
Dec 21, 2005 04:19 PM
