trany & ABS
Old Aug 8, 2010 | 12:35 PM
HERVE11262's Avatar
HERVE11262 is on a distinguished road
Angry trany & ABS
I have a 1999 trailblazer the trany is whining is seems to be shifting fine & abs light on pulled codes have a PO174 & PO171 has anyone had this problem
Old Aug 8, 2010 | 02:16 PM
P0171 - Fuel Trim System Lean Bank 1
P0174 - Fuel Trim System Lean Bank 2
Do you have any exhaust leaks?
Your ABS system has to be read by a compatible scan tool (high feature). Generic OBD2 scan tools cannot access it.
Is the whine fairly constant or does it fade a bit above 1800RPM or when the torque converter locks up when in overdrive? There are a number of possibilities that can cause a whine from the transmission. Torque converter, front pump, etc. There are also other things that can cause it; alternator, power steering pump, etc...
BigMarcus
Oct 29, 2007 09:26 AM
mdemers2006
Jul 26, 2007 06:41 AM
MNHawk
Jul 9, 2007 11:00 AM
mikehillis1@yahoo.co
Engine & Internal
Dec 19, 2006 12:45 AM
codereddanger84
Dec 11, 2006 11:50 AM
