TRZ Motorsports control arms
Old Oct 7, 2013 | 07:45 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Default TRZ Motorsports control arms
Anyone tried these out? the look like quality stuff and TRZ makes top notch products, so I suspect they are, also.
Upper and Lower Control Arms (Stock Spring) -
Product Description
Includes:
  • 2 Upper Control Arms, 2 Lower Control Arms, Assembled with Balljoints and
  • Control Arm Bushings, and 2 Limiter Bolts.
  • Built-in 7 Degrees of Positive Caster
  • Designed to Replace Stock Control Arms with No Modifications
  • Reduces Weight by up to 15lbs Per Side
  • Uses a Stock Spring and Shock or the QA1 PRO-Coil System
  • Uppers Come with Limiters in Place to Control Front Suspension Travel
  • Designed for Drag Race Applications Where Spindle Caster Can Range from 0 to 10 Degrees
Attached Thumbnails TRZ Motorsports control arms-img_7452-e1346454164755.jpg
Old Oct 7, 2013 | 10:48 AM
LeWhite's Avatar
The bottoms look like they might lower the ride hight. That and extra caster is something we need. Can they come without thr ball joints cause I want the tall ones? Wonder did the extra caster come from the top or bottom arm?
002blazerdude
Lifting Tech
Oct 27, 2010 09:43 AM
Yooper
Jul 26, 2009 03:01 PM
warhammer44
Suspension Tech
Oct 28, 2008 10:56 PM
TruckeeT2
Performance & Brainstorming
Jun 30, 2008 07:26 PM
TruckeeT2
Jun 30, 2008 05:00 PM
