Turn signal module always clicking....
Old Jul 8, 2008 | 07:25 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: Turn signal module always clicking....
I would double check at the dealer if you have an open 'campaign' on your vin# for this issue. Some did-it would only take a phone call or a visit-I've had a few customers with the 'lucky' vin# and got theirs repalced for free. Worth a try. jp
Old Jul 8, 2008 | 08:39 AM
Smoked's Avatar
Smoked is an unknown quantity at this point
Thanks for the tip. They did check my vin against any bulletins for this issue and i didnt' get lucky
ORIGINAL: Peru Motors
Old Jul 28, 2008 | 07:45 AM
Smoked's Avatar
I wanted to update this thread for future search results. I swapped my multifunction switch and the problem went away with the new switch.
I had two difficulties in this job... one, the top panel of the steering column is held on by a reverse torx screw which i got off with a 5/32 socket once i found it(it's on the ignition side of the panel, underneath. The next challenging part was the second torx screw holding the switch in place. It's so close to the steering wheel i didn't have anythign small enough to get in there with a torx bit to get it out. I ended up taking a big vice grip and pinching the torx bit in really tight to basically act as a wrench... it was slow going but it worked! Now that i've done the job, i would say top to bottom including removing all the panels i could do it in about 1/2 hour.
Old Jul 28, 2008 | 11:14 PM
Spartan66's Avatar
Spartan66 is an unknown quantity at this point
I get that ticking too but its some how tied into the red light above my CD player. When i unlock my door it starts and usually just goes off after awhile. Whats the red flashing lights function and would a hazard switch fix the flashing and clicking?
Old Nov 28, 2009 | 08:05 AM
Marcin's Avatar
Marcin is an unknown quantity at this point
Hi All
I try to find procedure of replacing hazard switch or just buy part in GM stores and I can not. Is it really possible to remove the issue in different way than chage of all multifunction switch?
Regards, Marcin
Old Nov 28, 2009 | 06:29 PM
Did you read everything in this 15 month old thread? The part numbers are listed. The parts are readily available on a number of online stores that ship internationally. Replacing the hazard switch would be the the "different way".
A quick search would have turned up Taymacjack's Broken Hazard Switch Repair DIY article in the Tech Article (DIY) section.
cameraman12
Jun 17, 2012 02:07 PM
Blazinflaboy
Jun 22, 2010 09:03 PM
ta3ff
Oct 14, 2009 05:07 PM
stlarry
Jul 22, 2009 01:29 AM
shaka1111
Feb 13, 2006 02:23 PM
