Turn signals
Old Feb 14, 2012 | 06:21 PM
GMCrazy14's Avatar
GMCrazy14 is on a distinguished road
Default Turn signals
2000 4x4 blazer left turn signal blinks fine right turn signal blinks 100 mile an hour thought maybe a bulb but there all workn fine any ideas thanks
Old Feb 14, 2012 | 06:36 PM
pettyfog's Avatar
With the right blinking, cycle the hazard switch a couple times.. hold it toward you
Old Feb 14, 2012 | 06:38 PM
I'd go have a look at the bulbs again just to be sure. There are multiple bulbs in the circuit that have to illuminate to properly load the flasher module allowing for normal flash pattern. The easiest way to make sure that all of the bulbs are working as required is to have someone inside the truck turn on the left then right turn signals while you watch the side that works & compare directly to the side that doesn't, looking at each bulb.
If everything checks out, then it may be a problem internal to the multifunction switch as PF has referred to. Check out the Tech Article (DIY) section for some threads on how to fix the hazard switch without overspending (if that is your problem).
Old Feb 15, 2012 | 04:20 PM
GMCrazy14's Avatar
Yup it was just a bulb didnt realize both bulbs lit up on the rear top was blinking the bottom wasnt, just got this vehicle and gettn to know it thanks for the replies, appreciated
Old Feb 15, 2012 | 06:05 PM
Glad you got it fixed! It always pays to take a second or third look, comparing side to side to make sure that all of the bulbs are illuminating properly. Just one of those little bulbs being out can cause the hyper flash! Best to make sure bulbs are not the issue before diving deeper into it!
SubbinBlazer
May 24, 2013 12:56 PM
BlaZeR FXB1581
Jan 22, 2006 11:51 AM
BlaZeR FXB1581
Sep 2, 2005 07:41 PM
mendez918
Mar 3, 2005 11:42 PM
blazin97
Feb 22, 2005 01:49 AM
