turn singnals
Old Jun 9, 2010 | 02:53 PM
banshee386's Avatar
banshee386 is an unknown quantity at this point
Default turn singnals
my turn singnals went out on my 95 blazer none of them work when i hit the turn singnal lever. but they all come on when i hit the four way button up top the sterring wheel any idea's im hoping its not the switch
Old Jun 9, 2010 | 08:36 PM
Dan 128's Avatar
Dan 128 is on a distinguished road
If you lost both left and right then it may be the switch. but first locate your signal relay. Some models are in the dash near the radio, some are behind the glove box door. I'm not sure on where a specific year or model is. Do a search on here someone may have posted a how to of some sort or call the dealer and ask. Either way I'd start with the relay it should be the cheapest and least involved task.
Old Jun 12, 2010 | 12:42 AM
banshee386's Avatar
alright thanks i will check that any other idea's i can look at while im outside
Old Jun 12, 2010 | 12:54 AM
bandidolenny's Avatar
Check the flasher relay...
Old Jun 13, 2010 | 11:30 AM
banshee386's Avatar
ok being how my four ways work wouldnt the relay still be good or is that on a differnt relay? and also were is the relay located
Old Jun 13, 2010 | 03:42 PM
banshee386's Avatar
ok i found the relays could i use the 4 way flaser relay in place of the blinker relay to see if they would work then or are they two differnt relays and would not work
SubbinBlazer
May 24, 2013 12:56 PM
gturzer
Mar 25, 2013 05:00 PM
ta3ff
Oct 14, 2009 05:07 PM
shaka1111
Feb 13, 2006 02:23 PM
blazin97
Feb 22, 2005 01:49 AM
