Turns over but no start... Help!!!
Old Jul 8, 2011 | 09:34 PM
W350_1992's Avatar
W350_1992 is on a distinguished road
Exclamation Turns over but no start... Help!!!
Hi Im new to this forum. I have a buddy that has a 2001 olds bravada with a 4.3L.
He was driving down the road and it died, no signs of problems before it quit. All it does is just crank over. We replaced the battery, crank sensor, and cam sensor so far with no luck. Also we pulled coil wire and spark plug wires and seem to be getting a good spark everywhere. I can hear the fuel pump kick on when the key is turned. Got me puzzled...
Any ideas anyone??? Any ideas or input would be helpfull, thanks.
Old Jul 8, 2011 | 10:04 PM
kevlar974's Avatar
kevlar974 is on a distinguished road
Have you checked the fuel pressure?
Old Jul 8, 2011 | 10:08 PM
xgiovannix12's Avatar
id start looking at the fuel pressure . you can get the tool at your local auto parts if they have loan a tool programs set up . unless you could buy it it should be around 30 bucks .
also look at the 2 help links in my signature they might help you out
Old Jul 9, 2011 | 12:50 AM
chaoticdopey's Avatar
chaoticdopey is on a distinguished road
just be advised autozone will loan the tool but with a $150 deposit which you get back once you return it. just a heads up
Old Jul 9, 2011 | 08:21 PM
W350_1992's Avatar
Thanks for the tips, we'll check the fuel pressure and see what we get. Also, could there be a wire connection somewhere loose? We got a wiring diagram for it, just wondering if there were and common problems to give a place to start.
Also wanted to re-state that the fuel pump does come on and the little valve stem on the fuel pipe does spray some fuel out when pushed when the key is turned on then off.
Old Jul 9, 2011 | 09:39 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
Why did you replace the battery if its turning over? Troubleshoot the problem instead of throwing parts at the problem. Too expensive.
Just because you hear the pump doesnt mean it is making enough pressure.
One quick way to see if its getting fuel is to give a a SHORT shot of starting fluid. If it fires and dies then you arent getting fuel for some reason.
Do you still have the old parts that are still good?
Old Jul 10, 2011 | 10:16 PM
W350_1992's Avatar
Battery needed changed bad anyways, would'nt crank over very long. Also it has threw a code for the crank shaft sensor awhile back thats why we changed it. All the wiring to the sensors checked out good.
The fuel pump quit all together now, so thats probly it. Its a nice looking vehicle but what a nightmare, one thing after another, then another.
Once again, thanks.
Old Jul 11, 2011 | 02:34 AM
bsbob's Avatar
bsbob is an unknown quantity at this point
mine too .2001 .replaced battery,fuel filter,ran fine for 2 days-now just cranks and cranks!!not looking forward to dropping the tank if its the fuel pump.u can get them alot cheaper on amazon by the way.read something about a fuel pressure regulator too i wonder if that is an issue
Old Jul 12, 2011 | 12:56 PM
W350_1992's Avatar
Thanks "bsbob". Im thinking about trying to test the fuel pump and regulater, is there any way to test them without dropping the tank???
Old Jul 12, 2011 | 02:27 PM
There is a fuel pressure test port on top of the motor on the main fuel supply line. You will need the appropriate test gauge to test the pressure & leak down.
1998mom
Jul 30, 2013 12:03 AM
nolan
Aug 22, 2008 06:39 PM
alexedge
Apr 6, 2008 12:51 PM
ryandannar
Sep 13, 2006 05:19 PM
