Vacuum line sizes
Old 04-02-2012, 09:36 PM
jaybird33081's Avatar
jaybird33081 is on a distinguished road
Default Vacuum line sizes
So I have to replace my heater core in my 97 blazer. I figured since I am going to have the whole dash out I might as well replace the vacuum lines behind the dash, I have heard all kinds of suction/hissing noises back there so I am assuming its a vacuum leak and hoses are so cheap. But I do not know the sizes I need to get. If anyone knows please let me know =) thank you very much.
Old 04-03-2012, 05:28 AM
The lines under your dash should be a harder, more robust plastic line, not the soft rubber lines typically found under the hood. They should not need to be replaced unless they are broken.
Old 04-03-2012, 09:58 AM
aa21830's Avatar
aa21830 is on a distinguished road
Agreed. If you have 4wd, and your transfer case vacuum switch has never been replaced, you may have t-case fluid in your lines, which can provide some unwanted lubrication around the line connections. Vacuum will seal less effectively at the connections, possibly causing leaks.
Old 04-03-2012, 08:48 PM
hmm well thanks for the info guys. I will have to check and see if there is fluid in the lines. The truck has 190k on it and as far as I know nothing with the vacuum system has been replaced.
Old 04-03-2012, 09:03 PM
aa21830's Avatar
A little tutorial on t-case fluid in the lines:
T-case vacuum switch
Old 04-04-2012, 08:29 PM
Thanks AA looks like I gonna replace the switch. Might as well it's only 25 bux
Old 04-04-2012, 08:53 PM
aa21830's Avatar
Don't get the Dorman... The one I got lasted less than a year.
Old 04-04-2012, 09:10 PM
ok, autozone has a few diff ones all listed for my truck. Will this one work?
Duralast/Transfer Case Switch (SW3467) | 1997 GMC Jimmy 4WD 6 Cylinders W 4.3L SFI | AutoZone.com
Old 04-21-2012, 04:57 PM
Micscience's Avatar
Micscience is on a distinguished road
Thanks this is exactly what I needed thank you so much.
Xavier
04-11-2014 11:49 AM
Jesster
11-08-2013 10:32 AM
igs4dragon8
05-14-2013 09:52 PM
UMichHockey
03-21-2013 07:53 AM
Ryanesque
Tires and Wheels
10-22-2008 06:22 AM
Quick Reply: Vacuum line sizes
