valves discolored
Old May 2, 2010 | 02:23 PM
TireGrit's Avatar
From: Hanover County, VA..Mechanicsville to be exact.
TireGrit is on a distinguished road
Default valves discolored
When replacing the intake manifold gaskets, I noted that the drivers side valves were light golden brown in color, but the passenger side valves were nice and metallic/silver colored. What would cause this and does this indicate a problem??
Old May 2, 2010 | 08:55 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
What valves are you referring to? The only valves I can think of are the intake and exhaust valves, but you shouldn't have been anywhere near being able to see those.
So what is it?
edit: here's a pic. Describe what it is that you're referring to.
Old May 2, 2010 | 09:44 PM
TireGrit's Avatar
My mistake. I also replaced the valve covers (that's what I meant to describe) and when I had both of them off, the driver's side was light gold brown and the other looked metallic silver.
Old May 3, 2010 | 07:19 AM
If you are comparing the color of the rockers, springs, etc... I wouldn't worry about a variation in color there. Especially when you say they are silver on one side and gold/brown on the other. So long as things are not black, you don't really have anything to worry about.
I will explain the reason for the color difference for you to further put your mind at ease. The PCV valve is on the driver side. PCV = positive crankcase ventilation. It uses manifold vacuum to pull excess pressure/vapors off of the crankcase via the driver side valve cover. To make up the air pulled through the PCV valve, there is a fresh air makeup tube that connects to the passenger side valve cover. The reason for the color difference is likely due to the volatilized oil/air mixture that is being drawn from the crankcase through the driver side valve cover into the PCV system.
Old May 3, 2010 | 10:36 PM
TireGrit's Avatar
Very informative and very simply explained. Thanks!!
Old May 3, 2010 | 10:58 PM
I aim to please! LOL
NOs
Sep 1, 2016 12:09 PM
lakeblazer91
Feb 16, 2009 02:55 PM
strong blazer
Apr 6, 2008 02:22 PM
dude5l
Jul 19, 2006 01:00 AM
R.R
Mar 8, 2006 10:57 PM
