various (wiring?) problems
Old May 10, 2009 | 06:45 PM
mark97s10's Avatar
mark97s10 is on a distinguished road
Default various (wiring?) problems
97 4 door 4x4 blazer. started out with rear wiper running slow at times, not at all others. then horn honking intermittently on its own. now power door locks and lumbar support inflation intermittent - seems that moving around in the driver seat affects it - lean toward passenger seat & locks buzz when you activate the switch. I have the driver seat out , console & carpet up - expected to see something obvious (cut or frayed) but everything looks fine. Any suggestions?
I did have winshield wiper stop a while back - took out motor & could find nothing. Finally re-soldered terminal connections on the circuit board of wiper motor & it worked fine. Must have had cracked solder joints.
thanks!
Old May 10, 2009 | 07:31 PM
Look at the wiring under the driver side carpet. Pull it up and look for signs of corrosion. I do not think this would explain the rest of your symptoms, but it would have to do with the seat.
BlaziNator
Sep 22, 2014 12:35 AM
sscandyman
Apr 25, 2011 06:09 PM
callen82
Jul 30, 2009 01:51 AM
lukejwise
Apr 2, 2009 01:38 AM
returnofsid
13
Jun 3, 2008 01:21 PM
