Vent Valve on Gas Tank
Old Aug 31, 2014 | 09:14 AM
madmaxh3's Avatar
madmaxh3 is on a distinguished road
Default Vent Valve on Gas Tank
My '97 jimmy (4dr., 4wd) has a "fuel tank vent valve" on top at the front of the tank.
Has anyone ever had to replace this, and if so how ?
Old Aug 31, 2014 | 10:35 AM
abig84's Avatar
i think the vent vavle is off to the side somewhere, some gas tanks just have a little plastic vent on top of the tank that usually dont go bad unless you physically break it.
Old Dec 14, 2020 | 03:53 PM
Zach Foxtrot's Avatar
Zach Foxtrot is on a distinguished road
Default Do I need to drop the tank again?
Now that I finally got her running, it's either a leaky tank, a line from above the tank, or I broke the vent off. I'm leaning heavily toward the vent tube.
I changed the pump yesterday (while the tank was out, I cut an access hole in the floorboard to make future maintenance easier. I did not nick a line. 5000% sure.) While the tank was out, I installed a new vent valve btw. It was super tight when last seen.
My question is:
Do I have to pull the (now full) tank out again in order to change the valve?
It's a 97 4 door 4 wheel drive Blazer.
Thanks in advance.
Old Dec 29, 2020 | 12:24 AM
Mods's Avatar
Plastic tank?
if so there is a replacement part for it if you need to replace it.
GM P/N #15640448 - Rollover Vent Valve, can be had on Rockauto for super cheap. havent gotten around to replacing mine yet.. its been laying in the rear drivers door cupholder lol.
Old Dec 29, 2020 | 03:01 AM
Monkeywrench71986's Avatar
Monkeywrench71986 is on a distinguished road
My question is:
Thanks in advance.
check feed and return lines for cracks and verify clips are fully secured, the return line is shorter that feed side and crack easily even when new. Did fuel pump on my blazer yesterday and broke the return line and the pressure sensor no joy to fix. I have accidentally cracked heat fitted fuel lines in the past on these.
richards2004
Oct 10, 2020 07:24 AM
McCormick_4723
Oct 10, 2020 12:44 AM
ve3nsv
Mar 23, 2012 04:45 PM
lacanars
Mar 28, 2011 12:39 AM
97MikeBlaze
May 26, 2010 02:49 AM
