Vibration
Old Dec 22, 2007 | 05:57 PM
wiskeyguy's Avatar
wiskeyguy is an unknown quantity at this point
Default Vibration
Hello everyone,
New guy here. I was checking the net and found this site about 1hr ago. After doing some searching i decided to join.. Lots of info... Great site..
Now my question:
I own a 2000 Chevy Blazer 2wd. I am having a vibrating problem at highway speeds. I had the wheels balanced and suspension checked. Now it feels like it starts in the rear and works to the front through the floor boards and the it will start to shake the whole truck. Could this be the wheel bearigs? If so should i just bite the bullet and replace all wheel Bearings? It has 82,000 miles. Thanks for the help
Old Dec 22, 2007 | 06:59 PM
Default RE: Vibration
Slide under your truck and grab a hold of the driveshaft. It is quite possible that one of the universal joints in the driveshaft has gone bad.
Old Dec 22, 2007 | 09:44 PM
wiskeyguy's Avatar
great thanks for the help i will check in the am
Old Dec 22, 2007 | 10:59 PM
wiskeyguy's Avatar
no luck they are solid no play
Old Dec 22, 2007 | 11:13 PM
wiskeyguy's Avatar
i dont think it is the bearings because it was just aligned at a friends shop? the alignment was way out but he had little problem getting it back in.. now thinking of the problem. i have a few a little more info. When accelerating it vibrates more. say doing 65 then speed up to 75 it seems to be worse. also this is a thing that one minute it is vibrating real bad the next no vibration. could this also be a transmission problem??
sorry after lookign at the site realized i should of posted in the Steering, Suspension & Drivetrainforum
Old Dec 24, 2007 | 09:35 AM
wiskeyguy's Avatar
does anyone have access to TSB info.. i found on another question site that there is a TSB that states this is a normal problem no fix just deal with it!!! What the hell.. anyways if you can i will provide the VIN number
Thanks
Old Dec 24, 2007 | 01:29 PM
Hanr3's Avatar
Welcome to the site.
Read through this thread and then lets talk.
https://blazerforum.com/m_25271/tm.htm
Old Apr 10, 2009 | 12:55 PM
ESKYMOPACK's Avatar
ESKYMOPACK is an unknown quantity at this point
I have the same problem with my 1999 Jimmy. At highway speeds, out of nowhere the rear (and floor) shake like theres a real bad U-Joint. Doesn't always happen, and doesn't happen at same speeds. Anotherwards, sometimes it comes and goes when it wants.
Now, the vehicle does have some ripe shocks all the way around, but I never heard of soft shocks creating this problem have you???
Also the front tires are in need of replacement, but this, like I said, seems to be coming from the rear.
Old Apr 10, 2009 | 01:03 PM
rriddle3's Avatar
Kind of an old thread. The OP has not posted since this 2007 thread.
Old Apr 10, 2009 | 09:35 PM
Bad shocks can allow some uncontrolled vibration in the suspension. There may be a certain point where you go over a bump and the speed of the vehicle causes the suspension to resonate (where the energy of the vibration input equals the energy being dissipated by the shocks). This is not supposed to happen with good shocks, but weak shocks can allow it.
KA3AX
May 4, 2006 03:08 AM
XBlazer01
May 1, 2006 03:30 PM
mattbbb14
Mar 23, 2006 09:46 PM
cthomson
Sep 7, 2005 04:51 PM
blazzinblazer1998
Feb 16, 2005 04:41 AM
