vibration
Old Nov 15, 2008 | 10:28 AM
blzrowner's Avatar
blzrowner is an unknown quantity at this point
Default vibration
I have a 99 trailblazer,when i get up to about 40 mph I get a vibration when the steering wheel is moved left and right.more noticeable to the left.........any thoughts?
Old Nov 15, 2008 | 10:33 AM
Default RE: vibration
It is quite possible that you have a wheel bearing that is starting to go or a component in the steering (idler arm, tie rod end, etc) that is worn and allowing play in the steering.
Another possibility is that you have something wrong with a tire. You could rotate the tires and see if the vibration goes away.
*Moving to 2nd Gen Tech* -
Tech questions should be posted in the appropriate tech sections. The new member area is for new member introductions.
Old Nov 15, 2008 | 12:53 PM
catdogs's Avatar
catdogs is an unknown quantity at this point
rotate and rebalance the tires.
KA3AX
May 4, 2006 03:08 AM
XBlazer01
May 1, 2006 03:30 PM
mattbbb14
Mar 23, 2006 09:46 PM
cthomson
Sep 7, 2005 04:51 PM
blazzinblazer1998
Feb 16, 2005 04:41 AM
