vibration
Old Mar 8, 2012 | 08:11 PM
bansheedave's Avatar
bansheedave is on a distinguished road
Default vibration
my 2002 blazer 4x4 has a nasty vibration. at about 55 miles an hour the truck vibrates threw the steering wheel. it will make the hands go numb. i do believe the vibration transfers threw the whole truck but mainly in the steering wheel. can it be the u-joints going bad or possibly tires? also when you go over bumps the front end wants to wander. could worn out control arm bushings cause that?
Old Mar 8, 2012 | 09:02 PM
mylittletonkatruck's Avatar
mylittletonkatruck is on a distinguished road
There are tons of things that can make your wheels vibrate: built up gunk (mud, brake dust, etc), unbalanced tires, missing balance weight... The wheels on my BMW vibrate from 55 to around 85mph because I have plugs in it and never got them balanced afterward. Not sure about a wandering front end, none of my vehicles have done that so I don't have experience with it. I would check control arm and tie rod ends.
Old Mar 8, 2012 | 09:58 PM
Cruiser64's Avatar
Cruiser64 is on a distinguished road
When I had bad u joints it would only vib under power and when I let off the gas to coast it would almost stop vib.
Old Mar 9, 2012 | 05:28 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
When I first bought my 2000 4x4 LT Blazer in 2002 it had new tires on it (Goodyear). It had a vib at around 70. Took it back to the dealer and they said it needs a balance job, I said okay and had it done. Didn't slove the probelm. But I was retiring and moving out here to AZ, so I waited until I got here and took it up the another Chevy dealer and explain to them. They said (Again) sounds like a balance probelm. So I left the truck with them and the next day they call me (Also had the A/C compressor change out). That the front end was fine and everything else. So they have this special balancer that turns the wheel a quarter of an inch at a time (Very time consuming and it wasn't cheap) anyhow 3 out of the 4 tires could not be balance and the 4th not a true balance. Now these tires were brand new. Didn't want to spend a ton of money of new ones, so I just rode them out until they were ready for replacement and put a good set of Mich on (And 677.00 dollars later) Problem slove. Still have the Mich on and they are working fine, I take the truck in when the time is ready for a rotate and balance and its been 5 yrs and they still look good.
Old Mar 9, 2012 | 08:32 AM
i'll rotate the tires and see if the vibration changes from front to back. two new(er) tires were put on the front after a blow out. this isn't my truck but a family members. ive already replaced ball joints twice, and the idler arm. swaybar end links. it never vibrated like this before so i suspect the tires. they swear up and down it's not.
KA3AX
May 4, 2006 03:08 AM
XBlazer01
May 1, 2006 03:30 PM
mattbbb14
Mar 23, 2006 09:46 PM
cthomson
Sep 7, 2005 04:51 PM
blazzinblazer1998
Feb 16, 2005 04:41 AM
