water on floor board
o ok guys maybe you can help?
I am getting water on the drivers side floor board of my truck.
I have checked the windows the sunroof and still cant find where it is coming from.
it seems like it is dripping for in side somewhere and falling by the base of the gas pedal .
dose any body have a clue of where it is coming from.
I have run water on the door the roof ,window and can not find leek .
I don't know what else to check.
RE: water on floor board
does it smell like antifreeze.
I was thinking the same thing but I thought failed heater cores usually drip on the passenger's side? How's your coolant level and/or temperature gauge?
you by chance arent walkin threw the snow are you, lol.
on it dose not smell like antifreeze.
everything is good. I only noticed it becouse it had rained a lot and the follr was wet.
I don't use the truck that mush I only use it on weekends
*Combining consecutive posts
no snow in texas
Please use the edit function if no one has posted since your last entry, thank you. TBB
no snow in texas
on snow in texas
i have the same problem is not the heater core but am pretty sure is either the door weatherstrip or the rubber that goes from the door to the frame that covers all the wire
If you're sure it's not a window or door seal, it couldbe following a wire, cable, or vacuum hose through the firewall from underneath the hood.
Ok....I am an expert on leaky blazers here...I had a passender rear floor leak for like 2 years....check the UNDERSIDE of the vehicle..I ended up finding a big gap underneath ...filled it up with caulk....no more leaks!
I second paddle_grl check under the truck, there is plugs in the floor if one is missing then thats were water is coming in from!!
