weird dash issue
Old Feb 27, 2017 | 03:55 PM
skrapper's Avatar
skrapper is on a distinguished road
Default weird dash issue
I have a 2001 Blazer that is having weird dash issues. When first started in the morning everything generally works fine. But then the whole instrument panel goes out, everything including the radio. At first I thought a circuit breaker was going bad because it will work for a short time. But there aren't any circuit breakers that feed the dash. Today I found that I can make it do the crazy thing it does at will. With the engine running and the dash dead I turned on the headlights the dash was still dead. Now the strange part I pulled the dimmer stalk to put the high beams on and the dash came to life even the radio worked. I let go of the dimmer stalk the dash went dead, pull the stalk dash comes to life every time. With the headlights off the dash is dead. I'm not sure if it's the dimmer stalk causing the problem or fixing the problem.
CrabbyClaw
May 5, 2016 06:31 AM
oswego
Oct 6, 2012 04:37 AM
gERgMan
Sep 6, 2008 07:27 PM
SilverTalon
Jan 27, 2008 08:31 PM
texastrails
Aug 25, 2007 04:10 PM
