Weird Electric - any idea's ?
Old Sep 19, 2007 | 11:01 AM
grovercan's Avatar
grovercan is an unknown quantity at this point
Default Weird Electric - any idea's ?
I've been a lurker for awhile and have found alot of good information, this timeI can't find anything real specific to my problem so I thought I would post and see if any of you have any good ideas.
The electrical problem I’m having is somewhat similar to this other thread but a little more extensive. When I’m driving down the road all of a sudden my whole dash goes crazy. The tach and speedo both flip to max and all the lights on the dash light up. This all happens very quickly. I do not notice any lose of power when this happens.
Other symptoms I have observed is engine noise feedback on the radio and the gear selector/ mileage read out sort of flicker. Also when I hit the brakes it appears the headlite dims or cuts out for a mili second. Sometime when I get in the car the clock has reset like it lost power.
This morning when I got to work and shut the car off, the whole thing went completely dead. No dome lights nothing when I turn the key just nothing. I worked for about 20 minutes and went back to check on it. I opened the door and the dome light was on. I tried to start it, the first time it would not start (turned over though) the 2nd time it started and died, the 3rd time it started and ran.
I think I got me a gremlin….and his name is not gizmo. With this being electrical I know I could spend hour chasing this thing and was hoping I could get some likely culprit ideas from the members here.
Thanks in advanced for any replies!
Ben
2000 Chevy S-10 blazer
Old Sep 19, 2007 | 05:29 PM
Default RE: Weird Electric - any idea's ?
Have you inspected the dash wiring harness for prior repairs/hacks/etc?? Some of this sounds like symptoms of a failing ignition switch, but some of the other systems are not related to that...
Old Sep 20, 2007 | 08:43 AM
grovercan's Avatar
I haven't check under the dash yet. I had it die on me this morning on my way to work. It completely blacked out. Nothing just as if there was no battery in. Everything turned right back on after a few seconds and took 3 trys to get started. I'm assuming the hard start has to do with the computer getting reset.
I'm leaning moretowards checking out the main power circuit. Does all the power run through oneof the computers and could this be a symptom of itfailing? Does any one have a simple wiring diagram for the main power circuit?
Any other ideas?
Old Sep 20, 2007 | 11:10 AM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
Loose ground cable between chassis and engine block.
Old Oct 5, 2007 | 05:06 PM
marlboromanx1875's Avatar
marlboromanx1875 is an unknown quantity at this point
i have the same problem just not as bad my truck hasnt cut off on me, yet, but im taking my truck to the chevy dealer to have it looked at i let you know what they told me.
Old Oct 14, 2007 | 01:57 AM
silentknight's Avatar
silentknight is an unknown quantity at this point
These are similar problems to what I have been having for quite some time now, still haven't tried fixing any of them yet tho, especially with new problem.
Old Oct 14, 2007 | 10:58 AM
gocartone's Avatar
gocartone is an unknown quantity at this point
Sounds like your alternator is going out.
Old Oct 14, 2007 | 09:06 PM
drperry's Avatar
If it's still got the AC Delco battery, check to make sure the terminals aren't corroded to poop...
toyblazervt
Nov 28, 2010 05:07 PM
dB Don
Oct 21, 2009 11:40 PM
stevenf
Aug 30, 2008 11:19 PM
punx.inc
Dec 25, 2007 12:07 AM
mojoman13
Engine & Internal
Sep 21, 2006 10:51 PM
