Weird noise
Old Nov 13, 2012 | 02:13 PM
brent1010's Avatar
brent1010 is on a distinguished road
Default Weird noise
Hi All,
Does anyone happen to know what this humming/whirring/whining noise is? It's been happening for a while and for the longest time I thought it might be the alternator but it finally died and I replaced it and that noise is still going. It's not coming from the speakers, doesn't appear to be the alternator, and finally this happens in both neutral, park, and on the road(as shown in the video kinda faint though with all the other road noise so turn the volume up to hear it) so I hope that rules out the tranny? The noise rises/lesses depending on how hard I am stepping on the gas/RPMs.
Thanks!
Old Nov 13, 2012 | 02:24 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Sounds like electronic humming through the speakers...
Old Nov 13, 2012 | 02:25 PM
4X4GS10B's Avatar
Pull the radio fuse to check
Old Nov 13, 2012 | 03:14 PM
richphotos's Avatar
It sounds like whine from the speakers to me honestly.
Old Nov 13, 2012 | 07:02 PM
brent1010's Avatar
WOW! I think you guys are right. I pulled the fuse and it instantly went away. Thanks so much. Sooooo glad it's nothing major.
Old Nov 13, 2012 | 07:40 PM
4X4GS10B's Avatar
I had this problem before and found that the ground was an issue.. But on this truck I have no idea which one it would be... Sorry..
Old Nov 14, 2012 | 10:18 PM
GMJim3687's Avatar
GMJim3687 is on a distinguished road
ground is probably an issue. do you have any aftermarket radio/amplifiers installed???
Old Nov 15, 2012 | 10:38 AM
Bigpappa305's Avatar
Bigpappa305 is on a distinguished road
most likely a ground I had a similar issue with a car i had put an airbag system on. I used one spot to ground multiple grounds for the relays to control the dump block and started getting feed back. I broke them up into two spots and the feed back went away.
Old Nov 16, 2012 | 07:06 AM
mmmrodge's Avatar
mmmrodge is on a distinguished road
unplug your cell phone charger
Old Nov 17, 2012 | 06:56 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
I had the exact same sound when I had a new aftermarket radio installed, and 1000 watt amp and subs... definatly the radio
gERgMan
Sep 6, 2008 07:27 PM
2dr5spdblazer
Oct 4, 2006 04:25 PM
blazinloud
Engine & Internal
Sep 10, 2006 07:01 PM
XBlazer01
Jul 19, 2006 02:53 PM
pepsi21463
Engine & Internal
Aug 13, 2005 12:35 AM
