weird noise from dash?
Old Oct 5, 2012 | 07:30 PM
oswego's Avatar
oswego is on a distinguished road
Default weird noise from dash?
There is a very annoying creaking noise coming from the dash behind the glove box. A couple people i have talked to thought that it might be the climate control but i wanted to get a second opinion to be positive. Anyone?
Old Oct 5, 2012 | 08:03 PM
warthogdriver's Avatar
depends...what is the truck doing when the noise occurs?
can you do anything that makes it happen...like move climate controls?
you could always take the glove box out and have a helper watch as you move the controls from position to position.
just some ideas.
Old Oct 5, 2012 | 08:10 PM
oswego's Avatar
Nothing really makes it happen it just automatically does it when i turn the key and theres no way to stop it. Is it a pain to take the dash apart?
Old Oct 5, 2012 | 08:16 PM
its not a pain but it takes some time.
does it happen when you start the truck all the time?
have you checked your vacuum lines? it could be having an effect on the vac controls for the dampers in the hvac system.
i would drop the glove box prior to starting the truck and have some one look in there when you start it...see if anything is moving to cause it.
Old Oct 5, 2012 | 08:29 PM
oswego's Avatar
yeah, it does it all the time. Its weird though because it sounds like the creaking is like switching gears..if you get what i mean. like the sound changes.
I'll drop the glove box tomarrow then and try and figure it out.
appreciate it
Old Oct 5, 2012 | 09:04 PM
yup...no problem.
having a helper should get it narrowed down quicker for ya.
Old Oct 6, 2012 | 04:37 AM
step66's Avatar
An issue I have noticed on these 2nd gen Blazers is if someone replaced the heater core and didn't re-install EVERY fastener,dash creaking ocurrs as these units have alot of body flex!
gERgMan
Sep 6, 2008 07:27 PM
2dr5spdblazer
Oct 4, 2006 04:25 PM
blazinloud
Engine & Internal
Sep 10, 2006 07:01 PM
XBlazer01
Jul 19, 2006 02:53 PM
pepsi21463
Engine & Internal
Aug 13, 2005 12:35 AM
