Well repair was almost perfect
Old Apr 28, 2019 | 04:11 PM
Trukntigger's Avatar
Default Well repair was almost perfect
Just a update from that mfi injector update repair on my 98-
Houston- we have a problem.
Not good, that’s not good.
Guilty location fixed.
So yea started noticing coolant on driveway. Brought into garage and yep, leaking but only when under pressure. Hard to find when hot so son’s pal had a tool to pressurize and test. Whole lot easier, found leak. Was clamp on recirculate line behind alternator down low. Thank gosh not the LIM gasket from that injector job, no way want to do that job anytime soon again. Pulled, moved a bit and relocated clamp a bit higher up on tube and tightened, tested under pressure 16lbs for 1 hour, no problem. Yippee. Figured I’d update you all on how it has been doing since that repair. Other than this which I just fix yesterday everything else A-ok. Running like a top. Still need to sort out rear wiper but nothing I can’t handle. Hope your all well- Tig
Old Apr 28, 2019 | 04:40 PM
cleburne red's Avatar
Good deal, man. It's always nice to be able to fix something relatively quickly like that!
RunninWild
Oct 17, 2013 08:45 PM
mattjphoto
May 12, 2013 04:09 PM
tripovermyego
Aug 14, 2012 02:51 PM
Cidium
14
Feb 20, 2011 01:08 AM
Tippman7641
Jun 7, 2008 08:34 PM
